2 members (klhansen, Otto Skorzeny), 47 guests, and 1 robot.
Topics128,036
Posts1,055,452
Members48,422
#41257 10/30/2004 11:52 PM
Got my cigars and a six pack ready to talk trannys. I have a 60 C10 that some time in it's life, the three speed was taken out and a four speed put in with the help of a torch. I'm going to put this back to original, I got another bell housing for it and I am trying to put a three speed tranny out of a seventies truck. The only problem so far is the front bearing retainer will not fit in the bell housing. I'm thinking I can take the retainer off and have it machined down so it will fit. Will this tranny work for me or should I be looking fot the right one. Any one got a match?
How much of a diameter difference is there in the bearing retainer, and will the standard throwout bearing fit once you've got the retainer OD right? It's usually necessary to make more than one modification, once you get started making changes.
#41259 10/31/2004 11:50 AM
The part of the retainer that needs to be machined is where it fits into the bell housing. The most that would have to be removed is 3/16. Who ever put the four speed in, took a torch to the bell housing and cut the opening bigger so it would fit. Any body else ever run into a problem putting a newer tranny in?
Have you checked to be sure the bolt pattern is correct, once the bearing retainer problem is solved? Just don't concentrate on one part of the fit problem, and then discover there are other concerns to deal with. How about overall length, driveshaft yoke spline, rear mount, if applicable, etc.? All these things can be dealt with, but it gets frustrating, trying to make something fit that was not designed to bolt together.
#41261 10/31/2004 10:52 PM
f63 Offline
Apprentice
Apprentice
They made at least two different size collars for the input shaft. I believe the bolt patterns are the same for both. It may be just a question of finding the right collar for your 3 speed and bolting it on.
'63 half-ton
another '63 half-ton
'62 school bus
#41262 11/01/2004 12:14 AM
Every thing looks like it wil fit, the bolt holes line up as well. I e-mailed a few tranny shops to find out if they make a smaller retainer. No answers back.
