2 members (ronsway, Hotrod Lincoln), 126 guests, and 2 robots.
Topics128,079
Posts1,056,312
Members48,442
Can I do a direct swap of hydraulic lifters for solids in my L6 250? It is out of a 72 impala. I do not know if the cam is stock, but I suspect it is.
I'm new to the L6 and couldn't find any posts that previously addressed this situation.
rcaster
No, It will need a solid lifter cam also. If you put solid lifters on a hydraulic cam it will chew it up fast.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
What wilbur said..
1952 Chevy Shortbed
Photos in Photobucket
I have solids now and want to switch to hydraulics
rcaster,
I am guessing you have the engine torn down enough to know you have solids. A '72 Impala would not have come stock with a solid cam and lifters.
Stuart
Riding in the Passing Lane
All 250's came with hydraulic lifters. You should not change lifters without changing the cam & vice versa. You might get by for a while but they won't live long.
1972 Chevy c10 Cheyenne Super
In addition to all that has been written above, there is no advantage to running solids unless you are building a high revving race engine.
Bob
55 Cameo 396 TH 400 with overdrive
65 Caliente conv
67 BB Caliente conv
67 Mercury 1 Ton
76 GMC 3/4 ton 454ci
84 Buick Turbo Regal
H Online: Content
The design of the cam lobe is different. Solid lifter cams have a long, relatively slow area of lift called an "acceleration ramp" that stacks all the parts together (lifter, pushrod, rocker arm and valve stem) before it begins to lift the valve off the seat. The acceleration ramp height just happens to be the same height as the clearance. (.012", etc.) At the other end of the lobe, the same thing happens, a slow, steady deceleration just before the valve contacts the seat, then another ramp to establish the clearance.
If you put hydraulics on a solid shaft, you get a radically longer duration, but no real performance benefit, since the lift is so slight on the ramps. Hydraulic cams have short, fast ramps, because they don't need to take up clearances before lifting the valve.
