8 members (Stovebolt48, Charles in CA, farmallb, Chip O, TooMany2count, 3800GUY, Wayne67vert, Otto Skorzeny),
40
0
Mod | | | Forums66 Topics128,006 Posts1,055,272 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | I am ready to install my brake lines on my 41, power brakes, master cylinder is mounted to the frame, disc in front, drum in rear. I was wondering if anybody could recommend a good universal brake kit or have any suggestions.
Thanks James
If it was easy, everybody would be doing it.
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | James just do some measurin and go to your local FLAPS and pick up lines in the lengths you need. the fronts you should be able to pick up close enough in length that with some finess you wount have to cut them at all, now the rear you prob. wont find one long enough but with a coupler you should be able to match 2 different lengths together to reach the rear end, goin this route will save you from having to mess with flaring ends and such. A trick I use is to take some stiff wire like "safety wire" is my choice, you can start and bend it around everything to your destination it will hold its shape, then straighten it out an get a measurement for how long of a line to purchase for that particular run. it is actually pretty easy to get your line length that way and head on off to your local parts store. Tim P.S. you can pick up a tubing bender very cheap at the parts store or online. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Tim is right on the "off the shelf" lines. Do that and save yourself a ton of headaches. another idea is to buy an assortment where you can return the unused lines. Then, like Tim suggested take a clothes hanger or some other heavy wire and make the bends you need. Then duplicate those bends with the real line.
~Jim
| | | | | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | Thanks for the info guys, what is FLAPS?
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Friendly,Local,Auto,Parts,Store or those black things that hang behind the rear wheels lol
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Oct 2007 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 58 | James, if you want to go the custom route you should check the Speedway Motors catalog (or go to www.speedwaymotors.com). They have kits with all the parts you need including the braided stainless lines. They also have a good variety of fittings in different sizes to fit various calipers and master cylinders. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | You could also check with Pure Choice Motor Sports http://www.purechoicemotorsports.com/That's who I used for the stainless flex lines and fittings.
~Jim
| | | | | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | Thanks dburban & big chev, I will check both of them out
James
