6 members (Donf, mo2cyl, Barney1951, Steelonsteel, Stovebolt48, TUTS 59), 78 guests, and 2 robots.
Topics128,031
Posts1,055,435
Members48,422
#41218 09/25/2002 1:47 AM
I have been working on a hesitation upon acceleration on my 261. part of it was carburator related but there is still a hint of it left. If I feel the distributor at rest I can move it in both directions and it feels real easy to move.
When I hit the gas I do see it move but not much, maybe 3/8 of an inch, then when I let off it kind of moves back but never all the way.
Is this just weak springs? How do I fix this?
54 3100 with 235
62 flatbed dump C60 with 261
#41219 09/25/2002 3:48 AM
Tony,
I had the same problem last spring. Luckily I had an extra vacuum advance mechanism - my old one barely moved the distributor. The good one greatly improved performance.
I might be misunderstanding your question because you also mention springs (for centrifugal advance?).
There is a diaphragm inside the vacuum advance (this might be bad).
http://www.tpub.com/basae/46.htm
Tim
#41220 09/25/2002 4:33 AM
I just assumed there was a spring that returned it back to the resting position? When I turn the distributor on my 235 it goes back into position as if pulled by a spring. The one on the 261 just kind of sits there and has much less resistance.
I actually have never had one apart so don't know.
54 3100 with 235
