4 members (Wayne67vert, Otto Skorzeny, Samantha, MNSmith), 43 guests, and 1 robot.
Topics128,154
Posts1,056,850
Members48,456
#412108 05/12/2008 5:25 AM
1 Offline
I did a search for a fan shroud for a 51 3100 but came up with nothing, Ive seen those cheap plastic ones that you have to cut out your fan opening, but has anyone seen or came up with anything better ?
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
Ill be watching this thread also, I do not have one & so far I do not need one for heating issues, but for safety's sake I owuld like to have a shroud over the spinning fan blade when Im adjusting things with the motor running.
1952 Chevy Shortbed
Photos in Photobucket
I bought one of the plastic ones from Chevy Duty,they have a different name now. Anyway I had to do a little trimming,but it works very well.
1 Offline
Dale: Is the plastic fairly sturdy ?
First I made a cardboard template and bent 2 halves out of sheet steel:
http://rides.webshots.com/photo/1377804539023244788VcLPaJ
Then I bolted it on and plug welded them together:
http://rides.webshots.com/photo/1377804563023244788BFDQpy
It works ok but the big fan is noisy. I'm going to switch to the water pump adapter and a smaller fan.
You Tube
Yes the plastic is sturdy. It is actually fiberglass and holds up very well.
