| | | Forums66 Topics128,180 Posts1,057,149 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 8 New Guy | | New Guy Joined: Sep 2007 Posts: 8 | I have a 47 Mint 5 window cab and no frame or box. I found a 55 first series nearby but that cab is shot. I was hoping the wheel base was similar but I remember reading that they changed? I want the 47-53 front clip and a flat rail box like on the 54-55. my question is. are the cab mounts and everthing in the same location. can I use the 55 frame and box for my 47 cab and clip. also are the hoods different for those years? | | | | | Joined: Jan 2007 Posts: 117 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 117 | is your 47 a second edition, that year it changed in mid yr, so if yours is 47 second and the same style as 48,49-54, your in luck
care to chat write back
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The '47 cab mounts are different from the later years but I'm sure it can be adapted. | | | | | Joined: Sep 2007 Posts: 8 New Guy | | New Guy Joined: Sep 2007 Posts: 8 | ITs a 47 or 48 from a Montana 1 1/2 ton. I was hoping it bolt right up? I'd lowball him and sell the extra parts on here. Great HOOD just not sure if it fit. | | | | | Joined: Sep 2007 Posts: 8 New Guy | | New Guy Joined: Sep 2007 Posts: 8 | second series? is first series like the 46? or are the 47's the same just bolted different? I only herd of 55 1st and 2nd series, not '47. new | | | | | Joined: Sep 2007 Posts: 8 New Guy | | New Guy Joined: Sep 2007 Posts: 8 | Is there a good book that has the differences through the years??? | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Ok, the '47 first look like 46'. The 47 second look like 48's and so on. Hope that makes it clear. | | | | | Joined: Sep 2007 Posts: 8 New Guy | | New Guy Joined: Sep 2007 Posts: 8 | | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | A 1 1/2 ton hood will not fit with 1/2-1ton fenders.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Sep 2007 Posts: 8 New Guy | | New Guy Joined: Sep 2007 Posts: 8 | Oh I know that. I have 1/2 ton fenders/hood, just the hood is a 55, didn't know if it fit on 47-53 | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Rear cab mounts will be different, the late 47 and the 48 cabs have a single centered rear cab mount, later AD years have two rear cab mounts, one on each side of the frame.
Chances are you can re use the style of cab mounts on the cab you like. You can not change the cab mount styles from one cab to the next, as the internal structure that supports the mounts is set up for one or the other, depending on year.
Grigg | | | | | Joined: Sep 2007 Posts: 8 New Guy | | New Guy Joined: Sep 2007 Posts: 8 | I want the box, but is the 55 frame do-able or I may hold out for a s-10? but that seems like work? | | |
