4 members (Jon G, Gray_Ghost, Bill Hanlon, MRMEROTH11), 85 guests, and 0 robots.
Topics128,068
Posts1,055,881
Members48,428
#411484 05/10/2008 1:47 AM
Y
Y Offline
Managed to get ID plate cleaned enough to see that the stamped identification number ?? H53L002145.
My Kansas title for the truck indicates that the VIN is HAD58805. What's up? Any ideas?
Tempe, AZ
Bill S.
Tempe, AZ
Your title appears to be using a 1950 passenger engine serial number instead of the number on the data plate you found. Why? Read the tech tip and check your engine serial number.
http://www.stovebolt.com/techtips/VIN.htm
Here is the HAD prefix decoded.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/showflat/Number/411116#Post411116
Hope this helps.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
randyl #411519 05/10/2008 4:07 AM
Y
Y Offline
Thanks Randy,
I appreciate the info.
Tempe, az
Bill S.
Tempe, AZ
Ex Hall Monitor
Ex Hall Monitor
Kansas used the engine number as the VIN through '55 as did most states.
Tiny #411699 05/10/2008 10:23 PM
what if the original engine is long gone?
1950 custom streetrod build
http://67-72chevytrucks.com/vboard/showthread.php?t=296770
71 corvette conv, 525 hp big block
50adrod #411730 05/11/2008 12:23 AM
Ex Hall Monitor
Ex Hall Monitor
Therein lies one of the big problems in changing engines, future titling issues. I think it's also the main reason the states went away from using the engine number. Every state has a process for resolving the issue. If you have a vehicle where the engine number was used but you don't have that engine any longer you'll need to contact your state licensing authority (where you get your tag/title transfered) to find out what their process is.
