7 members (Hanks custodian, 2-Ton, TUTS 59, Otto Skorzeny, festerhairball, HandyAndy, dt235sd),
83
Mod | | | Forums66 Topics128,060 Posts1,055,836 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 61 | Managed to get ID plate cleaned enough to see that the stamped identification number ?? H53L002145. My Kansas title for the truck indicates that the VIN is HAD58805. What's up? Any ideas? Thanks, Bill Tempe, AZ
Bill S. Tempe, AZ
| | | | | Joined: Mar 2008 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 61 | Thanks Randy, I appreciate the info. Thanks, Bill Tempe, az
Bill S. Tempe, AZ
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Kansas used the engine number as the VIN through '55 as did most states.
| | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | what if the original engine is long gone? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Therein lies one of the big problems in changing engines, future titling issues. I think it's also the main reason the states went away from using the engine number. Every state has a process for resolving the issue. If you have a vehicle where the engine number was used but you don't have that engine any longer you'll need to contact your state licensing authority (where you get your tag/title transfered) to find out what their process is.
