1 members (delky), 127 guests, and 3 robots.
Topics128,193
Posts1,057,258
Members48,466
#410987 05/08/2008 6:13 PM
Every once in a while, when I hit a big bump in the road, my TH 350 trans jumps out of gear into neutral. Thankfully, I can shift it back into drive without coming to a stop, however, its a little exciting !!. Any thoughts on possible problems / adjustments would be appreciated.
Thanks guys.
1940 Chevy KC 1/2-Ton
A bad motor or transmission mount? That would be my guess when you hit a bump it binds the linkage and kicks it in to neutral.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
Ditto on the bad mount. Put a block of wood between the trans pan and a floor jack, and jack up a little. If the tailshaft starts lifting off the crossmember, you've found your problem!
Riding in the Passing Lane
ALso check the detents in the trans. When you move the selecter down on the trans there should be a definite snap as it goes from one selection to another.
1972 Chevy c10 Cheyenne Super
Thanks guys...I'll check these items.
