1 members (delky),
127
Mod | | | Forums66 Topics128,193 Posts1,057,258 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Every once in a while, when I hit a big bump in the road, my TH 350 trans jumps out of gear into neutral. Thankfully, I can shift it back into drive without coming to a stop, however, its a little exciting !!. Any thoughts on possible problems / adjustments would be appreciated. Thanks guys. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | A bad motor or transmission mount? That would be my guess when you hit a bump it binds the linkage and kicks it in to neutral. | | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | Ditto on the bad mount. Put a block of wood between the trans pan and a floor jack, and jack up a little. If the tailshaft starts lifting off the crossmember, you've found your problem! Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | ALso check the detents in the trans. When you move the selecter down on the trans there should be a definite snap as it goes from one selection to another. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Thanks guys...I'll check these items. | | |
