0 members (),
309
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#4110 06/27/2002 11:40 PM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | I just bought some to paint my tube headers. Flat black finish. I bought the 16 oz can as opposed to the aerosol spray. Has anyone tried this?
It was about 9 bucks for the pint so I'm hoping it's good. I plan on doing two good coats over the headers before installing. | | | | | Joined: Nov 2001 Posts: 38 Member | | Member Joined: Nov 2001 Posts: 38 | I don't know about this one but most of the high temp paints need to be baked at 350 for them to work at the high end of their range. If they fit in your oven and your S.O. is ok with it bake them in the oven or a Bar-B-Que will work, use indirect heat in this one! And no sauce is needed!!
Steve Lemberg
1936 Chevrolet 1 1/2 ton truck 1970 Mercedes 280SE 3.5 coupe 1987 Mercedes 560SEC supercharged 1989 Mercedes 300CE 5.0 M119
#4112 06/28/2002 11:02 PM | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | Should work fine, but with all paint - proper prep! Sandblast preferred, handle with rubber gloves, thorough degreasing, etc. Small amounts of oil or contaminants can lead to big bubbles.
Paint should be fine, and at that cost not a big worry if you have to re-apply every year. Good choice for these trucks!
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
