| | | Forums66 Topics128,022 Posts1,055,387 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | What is the correct weight that is to be stamped on a data plate for a 46 1/2 ton pick up? i was at a recent car show and saw 1000, 2000, 3600 and 4800 lbs respectively. need to redo my plate and want the right info. thanks
ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
| | | | | Joined: Sep 2002 Posts: 153 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 153 | I checked mine but it was painted over. Only the Model and Serial Number is "stamped" in the metal. Mine is really a 1947.1 with the 3DP-J stamped into the metal. There is a picture on Chevs of the Forties Web Catalog and it saya 4600 lbs. http://www.chevsofthe40s.com/browse.lasso?&search=data%20plate&dept=truck&skip=1 1946 Chevy Half Ton ('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS) 1976 Margay Panther X, MC91B | | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | I'm not to sure the weight is that much, I've got a '46 1/2T Panel with a SBC and other stuff in it and on a certified public scale it's only 3200. I needed the weight to title it. The data plate has no weight on it either.
David Just a firefighter, Cleverly disguised as a responsible adult '46 1/2 T Panel
| | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | The 1/2 ton weight is 3010 lbs. the orig. data plate will most times only have two #'s stamped on it. The #'s don't indicate the year but the Gross allowable weight in 100's of lbs.
Shipping weight = 2870 lbs. Curb weight = 3010 lbs. Gross Allowable Weight = 4600 lbs.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
