| | | Forums66 Topics128,086 Posts1,056,331 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#41020 03/19/2003 3:37 AM | Joined: Mar 2003 Posts: 10 Member | | Member Joined: Mar 2003 Posts: 10 | I posted earlier about a 51 flatbed GMC that I may be buying. The hood emblem is 250. I was told that a 250 is a 1 ton, but the truck has larger axles (and duals) than the 1 tons I've seen that have very long pickup beds and are without duals.
The serial number (on the doorjam)is 25322C1119 which from the charts is a 1 ton, 137", 228, Oakland.
Could this be a 1.25 or 1.5 ton with a 1 ton cab? I'm 100% certain that the axles are way larger that my old '53 3/4 ton.
Sidehill | | |
#41021 03/19/2003 4:02 AM | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | Go to oldgmctrucks.com to decode you serial number. | | |
#41022 03/19/2003 4:51 AM | Joined: Mar 2003 Posts: 10 Member | | Member Joined: Mar 2003 Posts: 10 | Originally posted by afu45: Go to oldgmctrucks.com to decode you serial number. Been there done that. Serial number decodes as a 1 ton. Problem is that the axles and wheels are much heavier than any 1 ton I've seen. Thanks for the input though. Sidehill | | |
#41023 03/19/2003 1:31 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | The axles would be larger than the 3/4 ton...that's why it's a one ton.
One tons had 17" and optional 18" rims. Which does this have? 7 leaf 2" front and 8 leaf 2" rear springs too. | | |
#41024 03/20/2003 4:49 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I believe the 1-ton should have 8 lug wheels and the larger ones have 10 lug on rear and 5 lug on front. (same wheels but only uses 5 of the holes) | | |
