2 members (ShopRag, DaveV), 97 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#409593 05/04/2008 3:10 PM
What type of a switch is used for the fan motor on / off in a 49pickup? can you use a toggle as the heater has a temp control or maybe a high/low type switch to control the speed, would like some input please.
sader dog
saderdog #409606 05/04/2008 4:35 PM
saderdog,
If you only want to turn it ON and OFF, a good quality toggle switch will work. The heater blower motor doesn't draw lots of power.
Making the blower motor speed adjustable is another matter though. Slowing the motor from its designed speed by reducing voltage would require a rheostat, and it would have to be designed for the voltage and current application.
The specialty suppliers should have switches listed that were actually used on these rigs for the blower motors. Have you looked in the LINKS tab for folks that deal in Stovebolt stuff.
Stuart
saderdog #409611 05/04/2008 4:40 PM
-> Here are aftermarket 6v & 12v heater switches. They are sold by most restoration parts vendors.
-> yes (some GMC trucks used a three-way toggle switch)
-> yes
tclederman #409626 05/04/2008 5:09 PM
The high low will only control amount of heat by fan speed. The way to change the temperature output is by controlling the amount of hot engine coolant going through the heater core with some sort of a mechanical valve.
Greg_H #409653 05/04/2008 7:48 PM
Ex Hall Monitor
Ex Hall Monitor
In 49 they most likely used the rheostat fan switches that hung under the dash. Take Tim's link then put "heater switch" in the search box.
Tiny #409704 05/04/2008 11:12 PM
Thanks, Tiny
The I guess that the search code did nor persist beyond my session.
The original switch was not a rheostat-type but no one makes the original-style switch. The original switch looked like this with a black or ivory/white "lever".
Tim
tclederman #409928 05/05/2008 2:29 PM
Ex Hall Monitor
Ex Hall Monitor
I sure haven't found anyone repoping the paddle switches but I see them fairly regularly on ebay. My 55.1 had the red rheostat switch under the dash.
Tiny #411873 05/11/2008 3:51 PM
Tiny I had a paddle switch that was sporadic so i purchased a rheostat type as shown in the classic parts $11.95 and it work like a hot dam it even lites up ... I took the bulb out the lite was to bright... the heater works great now... Peter
jdl Offline
Guess I found out what that mysterious switch was for under my dash, then. Looks to be in good shape...
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
jdl #411892 05/11/2008 5:03 PM
Ex Hall Monitor
Ex Hall Monitor
Yup, they were used to control the heater, defroster & I've seen a couple on ebay that had "fog" on the paddle which I'm assuming were to control the fog lights. I don't see why you couldn't use one to control about anything that needs a switch. As long as you don't exceed the amperage capability of the switch, the switch doesn't care. grin
