| | | Forums66 Topics128,022 Posts1,055,382 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 23 New Guy | | New Guy Joined: Aug 2001 Posts: 23 | What type of a switch is used for the fan motor on / off in a 49pickup? can you use a toggle as the heater has a temp control or maybe a high/low type switch to control the speed, would like some input please.
sader dog
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | saderdog,
If you only want to turn it ON and OFF, a good quality toggle switch will work. The heater blower motor doesn't draw lots of power.
Making the blower motor speed adjustable is another matter though. Slowing the motor from its designed speed by reducing voltage would require a rheostat, and it would have to be designed for the voltage and current application.
The specialty suppliers should have switches listed that were actually used on these rigs for the blower motors. Have you looked in the LINKS tab for folks that deal in Stovebolt stuff.
Stuart | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | would like some input please. What type of a switch is used for the fan motor on / off in a 49pickup? -> Here are aftermarket 6v & 12v heater switches. They are sold by most restoration parts vendors. can you use a toggle as the heater has a temp control -> yes (some GMC trucks used a three-way toggle switch) or maybe a high/low type switch to control the speed, -> yes | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | The high low will only control amount of heat by fan speed. The way to change the temperature output is by controlling the amount of hot engine coolant going through the heater core with some sort of a mechanical valve. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | In 49 they most likely used the rheostat fan switches that hung under the dash. Take Tim's link then put "heater switch" in the search box.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I sure haven't found anyone repoping the paddle switches but I see them fairly regularly on ebay. My 55.1 had the red rheostat switch under the dash.
| | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | Tiny I had a paddle switch that was sporadic so i purchased a rheostat type as shown in the classic parts $11.95 and it work like a hot dam it even lites up ... I took the bulb out the lite was to bright... the heater works great now... Peter | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Guess I found out what that mysterious switch was for under my dash, then. Looks to be in good shape... | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Yup, they were used to control the heater, defroster & I've seen a couple on ebay that had "fog" on the paddle which I'm assuming were to control the fog lights. I don't see why you couldn't use one to control about anything that needs a switch. As long as you don't exceed the amperage capability of the switch, the switch doesn't care.
