| | | Forums66 Topics128,089 Posts1,056,009 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | Was given an 83' rear seat out of a Chevy Suburban yesterday. I removed the arm rests and put her in to check the fit. Pretty good but need ideas on how to mount it. I have the gas tank under the seat and the filler neck prevents the passenger side of the seat from resting directly on the floor/fuel tank frame in the rear. If I raise the rear up 3 1/4" it will clear and the seat sits just about level. Ride height, pedal reach. etc. feel good to me from behind the wheel. So have any of you made rear brackets of platforms for an install simular to this, and if so how you do it? Thanks in advance for ideas, Brett
| | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | I installed 2 fiero seats in my '41. I welded 2 brick window lintels together into a Z and used that for the back mount. It gets the height up so the filler neck only comes in a couple incnes but does not interfere with the seat mount. Raising the rear of the seat makes a much more comfortable seating position. I added a piece of 16 ga steel to cover the tank. I welded the seat frames to angle iron. I added a piece of punched angle to the inside of the front edge of the tank surround and fastened it with "stovebolts". I then welded nuts on the bottom sides of the punched angle and the "Z" back mount and fastened the angle iron to those nuts.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | Well, the seat is in and the pics are on the Fliker site. Shows all mods required for a 83 Chevy Suburban third seat. Everyone is right they do fit nicely, with a day of work. Ready for cover! Thanks Harold for the idea. Brett | | | | | Joined: Jan 2007 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 63 | we took the seat frame and cut where the filler tube was then welded the piece back in to clear the tube | | |
