1 members (stlcardinalsguy), 71 guests, and 1 robot.
Topics128,030
Posts1,055,430
Members48,422
When I bought my 1/2 ton 59, the PO had a Choke pull in the dash hole closest to the Speedo/Gauge Cluster on the left side of the column next to the headlight switch. It also had a Throttle pull in the dash panel hole above the Deluxe heater. Was this a standard OEM layout? Where did the choke (if supplied) pull go? The Electric wiper seems correct on the right side near the radio right? Thanks
~ Rasman
1971 Chevy C10
"Old Yeller"
Saga: "'Old Yeller' ... More than a Pristine 1971 Chevy"
1959 Chevy 1/2-Ton
In the Legacy Gallery
layout should be like this, if that's clear enuff
Very nice! Thank You Bill. Ralph
~ Rasman
1971 Chevy C10
"Old Yeller"
1959 Chevy 1/2-Ton
