| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | When I bought my 1/2 ton 59, the PO had a Choke pull in the dash hole closest to the Speedo/Gauge Cluster on the left side of the column next to the headlight switch. It also had a Throttle pull in the dash panel hole above the Deluxe heater. Was this a standard OEM layout? Where did the choke (if supplied) pull go? The Electric wiper seems correct on the right side near the radio right? Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | layout should be like this, if that's clear enuff Bill | | | | | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | Very nice! Thank You Bill. Ralph | | |
