7 members (TUTS 59, homer52, Otto Skorzeny, Youngin' Tut 59, dt235sd, 2 invisible), 122 guests, and 1 robot.
Topics128,052
Posts1,055,727
#405734 04/23/2008 2:50 PM
Just droppin a THUMBS UP on these items I have gotten.
1-lokar automatic shifter, Nostalgia bend for a TH350, install was EASY, Engineering was FANTASTIC!...looks great in a Ol AD
2-throttle cable (S.S.)very well thought out and and infinately adjustable from one end to the other for the user to CUSTOM make a throttle cable that looks like it was made especially for your ride!
A THANK YOU too the Engineers at Lokar!
Tim
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #405771 04/23/2008 5:28 PM
Amen to all but the throttle cable. ...haven't gotten that one yet but certain it will perform as well as the rest.
~Jim
Just recently got their parking brake cable kit. Totally impressed! Fitted without any hassle at all grin
Even better considering the exchange rate!! They cost $100 U.S incl shipping. Got my 'bud' in Va. to post them as a gift.
Avoided Import duty. U.K equivalent £50 approx! Result.
More pix on Flickr.
this is all good to hear because i just ordered a lokar floor mounted pedal assembly and throttle cable for my 52. Putting a clifford intake with holley 4bbl 390cfm street carb so im converting the pedal to cable.
http://www.lokar.com/product-descriptions/eliminator-fm-throttlepedals.htm
http://www.lokar.com/product-descriptions/throttle-cables.htm
drummin52 #405803 04/23/2008 8:00 PM
In my 55 I am using a Lokar floor shifter on my 700R4 automatic.I also have the Lokar E brake setup which mounts right beside the shifter.They work just fine,were easy to install,and gives the 55 that nostalgic look.
dale937 #406181 04/24/2008 7:32 PM
Friends - I'm going to go with the Lokar pedal and throttle cable on my Clifford intake with 390cfm 4 bbl too. Did anyone spec out the Lokar SS Carb Bracket with return spring to go with this setup? I'm not sure which one to buy at this point. Thanks - Bug
1951 Chevrolet 3100 AD Pickup
I used Lokar 42 to 54 E brake cables on my 37 to hook up the original E brake linkage to the 8 inch rear. Jeff
Jeff Ogden #407648 04/29/2008 12:10 AM
Have you noticed the Lokar throttle cable also needs the Lokar throttle cable bracket to work? Hope you ordered that too. Also well made. Although you can modify others to work, I feel it takes away from the fine quality of the Lokar throttle cable if you don't use their bracket also.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
For you guys with the Lokar shifter, did you also use the shift indicator? Did the shifter mount in the factory location?
Robert C.
I'm a Genius in the making.
1950 3600
I had to fabricate the tranny cover to fit my 700R4. I don't know about a indicator for the shifter.
http://good-times.webshots.com/photo/2969433960099708909ysndgn
~Jim
I used the shift indicator. It was a bear to get it set properly. Took alot of fine adjustment. In the process we lost a bolt or two. Called Lokar to see if they would send us out a couple of bolts, sure at $4 a piece plus shipping. Thought that was a little excessive. Only complaint I have with them!!
How long is your shifter?
Robert C.
1950 3600
U
U Offline
Used a combination on my truck.Made my own trans cover similar to bigchevy3600.Genie shifter with Lokar dash mounted gear indicator.A requirement for full registration here in Oz is to have a gear selection indicator. Lokar drive unit mounts to trans pan bolts with a lever connected to the shift selector. easy installation. gear indicator can be mounted anywhere in the cab you want governed only be wiring done by you or others for you
usa050aus #409273 05/03/2008 12:25 PM
I did not use the shift indicator.Besides it is printed on the shift ball. And oh yeah,I know what position it is in at all times,and I am the only one who drives it.I have also installed a Dakota Digital dash setup,so if I ever decide to use a trans. indicator it will be a Dakota Dash unit.
dale937 #409486 05/04/2008 3:09 AM
Ok, but what is the length of the shifter arm you guys chose, 10" 16" 23" 32"?
Robert C.
1950 3600
I got the 16".
~Jim
Im runnin the 23" Nostalgia bend,Only issue is if I put the TH350 into low (1st) the shifter is against the seat.
But it looks cool, I always get asked WHERES THE CLUTCH PEDAL?
Tim
1952 Chevy Shortbed
SW_Radial #409727 05/05/2008 12:46 AM
I,m running the same 23" Nostalgia shifter, comes real close in 1st gear to my seat also. I agree Radial, looks cool!!
Just bought a 16" off Ebay.
Robert C.
1950 3600
Interesting on the throttle and pedal assembly. My 1949 GMC has a 261 in it with two Holley Webers and the Offy linkage set-up. When you depress the pedal, it pushes the slightly bent accelerator rod which then pushes the top hole on the block mounted bellcrank. The bellcrank rotates counterclockwise and pushes the throttle rod up and rotates the Offy linkage to open the carbs. How would the Lokar work since the picture shows that the pedal, when depressed, pulls the throttle cable downward? I'd like to get rid of the mechanical accel rod if I can for a smoother and better foot response.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
49 geezer #410074 05/05/2008 11:27 PM
I believe Lokar has a few pictures on their web page. It may show how the set-up is for an inline.
~Jim
49 geezer #416473 05/25/2008 3:37 AM
Got it installed today. It wasn't the trans mount {mounts to the floor) but it worked out ok.
Robert C.
1950 3600
