1 members (Hotrod Lincoln), 57 guests, and 1 robot.
Topics128,094
Posts1,056,066
Members48,433
#409437 05/04/2008 1:28 AM
I'd like to lower my GMC or at least give it a rake till I put it on the sub frame I have. What's the best way to do it and not to costly?
Take some leaves out of the spring pack.
Bill Burmeister
just what longbox55 said. easiest and no cost involved at all.
although i installed a droped axle in my front, i also removed
1 leaf in front for an additional 1 inch, but in the back, i had to remove 4 of the 7 leafs to get a 2 inch drop.
it made it actually ride smoother.
you might want to look into a dropped front axle. a heck of a lot easier that cutting and installing a sub frame.
check out DROPPEDAXLES.COM
SID, is the owner, operator, and on heck of a guy to do business with.
check my photobucket shots. his 3 inch dropped axle and 1 leaf removed. i might drop the front 1 more inch in the near future, and will do that by removing another front leaf. and will install longer shackles in the rear for additional drop.
just a thought..
leonard.
1957 Chevy 3100 1/2-Ton
Photobucket pictures
