1 members (Forty9),
66
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40894 08/26/2003 7:37 PM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Have any of you "rich" guys out there had your tube headers (or cast iron manifold exhaust) ceramic coated? Many of the online testimonials I've read praise the results. It doesn't come cheap. This company http://www.amr-coatings.com/powdercoating-process.html gets 140.00 to do full length I6 street headers inside and out. That's pricey. Ken, Tony, chiphead - you guys are billionares a million times over. Have you had this done? -ftyler | | |
#40895 08/26/2003 8:07 PM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Unless your making you own headers you can be sure they are made from the CHEAPEST materials possable The manifold market's mostly about price. Givin' that.....coating makes the junk last longer | | |
#40896 08/26/2003 9:03 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Kinda unnecessary on cast iron exhaust manifolds. The steel tube headers benefit from coating cuz it keeps the header tubes from rusting/oxidizing so quickly.
Thanks for the link, I may ask you to repost it later. My '67 Lemans project will need a set of headers. I've heard its best to buy them uncoated, beat/mod them to fit in the car, then send them out to be coated.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#40897 08/26/2003 11:52 PM | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | $140.00?? That's not pricey! The two big firms doing this, HPC and JetHot, charge about $190-200 for in/out I6. I'm not rich, but then I don't have any kids to suck off my play money, so I popped for the coating on Clifford Headers.....don't tell my wife... Uncoated headers will turn to rusty crap in just a few years. The other thing that doesn't get mentioned much is underhood heat. Coated headers run MUCH cooler. Next time I start mine I'll check the surface temp and report back. If I remember correctly it was less than 175 at idle - that won't even sizzle water! | | |
#40898 08/27/2003 12:19 AM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | The headers will last forever coated or not. You coat headers for the same reason you paint your engine block, you want it to look nice.
I had my Fentons powder coated with an aluminized heat resistant coating.. Airborn Coatings in Hartford, CT did the work.. I had previously tried the Eastwood Spray Can Header stuff, it began to rust in less than a year. Airborn guarantees their work for three years..
I don't remember the exact price, I think it was a couple of hundred bucks. Remember ftyler, if you want to travel in the high speed lane, it costs money..
[img]http://home.comcast.net/~bd97/Fenton.jpg[/img]
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#40899 08/27/2003 12:34 AM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | The ceramic (chromocoting) process and powder coating is not the same. I had a new set of fentons and the stock intake manifold ceramic coated two years ago. With almost a 1000 miles on the engine they look every bit as nice as the day they were done. No rust anywhere and not a hint of blue. My cousin is in this business. Drop me an e-mail maybe I can get better prices than what I have seen here. T
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
#40900 08/27/2003 12:43 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Ftyler,yup,I got rich from never spending my money on fancy finishes  Ceramic is a nice touch,or light rust is fine too,it's just an engine,right? You should insulate the header pipes, supposedly,the hotter gases in the pipes flow quicker,and cooler underhood temperarures.But beware, some claim the insulation may allow the pipes to get get quite hot, and some headers may heat warp or crack due to the what Jim Proffit says.In time the insulation gets grungy,adding character to the engine compartment. | | |
#40901 08/27/2003 4:48 AM | Joined: Jan 2002 Posts: 20 Junior Member | | Junior Member Joined: Jan 2002 Posts: 20 | From what I've read , the biggest benefit is in reduced engine compartment temperatures. Second benefit, is more rust resistance.
I just pulled an old set of headers off another project. I'm sure they have been there a while. Big rusty holes, may have been prevented with ceramic coating. I think it's easy to ding or scratch this coating so that rust get's in as easy as uncoated headers.
62 1/2 Ton Stepside, 3 on the tree and 235 I6 Grandpa gave it to me, it is straight and original with about 90K original miles..
