0 members (), 72 guests, and 2 robots.
Topics128,072
Posts1,055,906
Members48,429
#408612 05/01/2008 7:27 AM
I have a 62 C20 with 4 speed trans. It is hard to down shift. I cant get it in to the lower gere untill the truck is almost stoped. Any suggestions?
Y
Y Offline
Which gears are hard to down-shift into? I have a '65 C20 with a 4 speed, you nearly have to stop to put in to 2nd and absolutely have to stop to put it into 1st. This is normal with the low gears that these trucks have. Your truck is probably fine unless you have problems going from 4th to 3rd.
Yaut #408799 05/01/2008 8:59 PM
Riding in the Passing Lane
Drllman is right. I usually double clutch downshifting to 2nd. You might change the grease in it useing a good 80/90 weight. That old grease in these gearboxes can get really raunchy.
1972 Chevy c10 Cheyenne Super
Thanks For the help
