1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 16 New Guy | | New Guy Joined: Feb 2007 Posts: 16 | I have a 62 C20 with 4 speed trans. It is hard to down shift. I cant get it in to the lower gere untill the truck is almost stoped. Any suggestions? | | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | Which gears are hard to down-shift into? I have a '65 C20 with a 4 speed, you nearly have to stop to put in to 2nd and absolutely have to stop to put it into 1st. This is normal with the low gears that these trucks have. Your truck is probably fine unless you have problems going from 4th to 3rd. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Drllman is right. I usually double clutch downshifting to 2nd. You might change the grease in it useing a good 80/90 weight. That old grease in these gearboxes can get really raunchy. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2007 Posts: 16 New Guy | | New Guy Joined: Feb 2007 Posts: 16 | | | |
