7 members (Jon G, Youngin' Tut 59, Lightholder's Dad, Ponchogl, 3 invisible), 121 guests, and 3 robots.
Topics128,132
Posts1,056,384
Members48,441
I'm at work at the moment, but plan to swing by Sears at the end of the day. I have a master cylinder rebuild kit on the way, and need to buy the properly sized flare nut wrench so that I can strip the fittings at the master cylinder prior to taking it off. What size wrench is needed?
Would it be better to skip the wrench purchase, save my money, and just strip the fittings with vise-grips instead?
I already bought some PB Blaster to make the job messy from the get-go.
Is it the same fitting size at the master cylinder as at the wheels?
One last question- what size hone should I be looking for to try to clean up the master cylinder cylinder? I want it to look good before I take it to a machine shop for re-sleeving.
(I guess from my tone, you are getting the feeling that I'm not expecting much from this project.)
Any advice appreciated.
Bill, just buy the set of 3 flare wrenches, (6 sizes).
A master cylinder hone is spring loaded to adjust to the size it's used in.
I know what you are talking about, with the wrench set. Will do.
The hone- I thought they came in size ranges. Am I needing one that is something like 3/4 to 1-1/4 inch diameters? How big is that ID? Is it as much as 1-1/2" I can't get my brain around it.
Bill,
I think the fronts are 1.25" Id and rears are 1.0". I put a $6.00 flaps rebuild kit in one of mine without honing it. Seems to work fine. FLAPS may be less for an assy than the machine shop; the part suppliers are way high on wheel cylinders. I found out the hard way I have some sticky pistons on my motorcycle (see my greasy spoon post 4/29) and I have cleaned those up years ago just using a scotch brite. Time to do it again. LOL.
Eric
http://s1199.photobucket.com/user/sparky234/library/My%2057%20Chevy%20Stepside?sort=3&page=1
'57 Chevy 3100 (Little Red)
'81 RD350 LC - Fun, Fun, Fun
'83 GS1100E - Pocket Rocket
Eric, I think you are referring to the wheel cylinders. I was wondering about the ID of the master cylinder.
That said, thanks for the info- I didn't realize I could buy WC rebuild kits locally, and for so cheap. Wow! That is good info to have.
inch & 1/8 for the TF master ... should be able to get kits for them at NAPA, whole new masters as well [Raybestos # MC21680], virtually all the TF brake parts are still available from Raybestos, Wagner, Bendix
Moderated by  MNSmith
