0 members (),
106
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | I'm at work at the moment, but plan to swing by Sears at the end of the day. I have a master cylinder rebuild kit on the way, and need to buy the properly sized flare nut wrench so that I can strip the fittings at the master cylinder prior to taking it off. What size wrench is needed?
Would it be better to skip the wrench purchase, save my money, and just strip the fittings with vise-grips instead?
I already bought some PB Blaster to make the job messy from the get-go.
Is it the same fitting size at the master cylinder as at the wheels?
One last question- what size hone should I be looking for to try to clean up the master cylinder cylinder? I want it to look good before I take it to a machine shop for re-sleeving.
(I guess from my tone, you are getting the feeling that I'm not expecting much from this project.)
Any advice appreciated.
Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Bill, just buy the set of 3 flare wrenches, (6 sizes).
A master cylinder hone is spring loaded to adjust to the size it's used in. | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | I know what you are talking about, with the wrench set. Will do.
The hone- I thought they came in size ranges. Am I needing one that is something like 3/4 to 1-1/4 inch diameters? How big is that ID? Is it as much as 1-1/2" I can't get my brain around it.
| | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | Bill,
I think the fronts are 1.25" Id and rears are 1.0". I put a $6.00 flaps rebuild kit in one of mine without honing it. Seems to work fine. FLAPS may be less for an assy than the machine shop; the part suppliers are way high on wheel cylinders. I found out the hard way I have some sticky pistons on my motorcycle (see my greasy spoon post 4/29) and I have cleaned those up years ago just using a scotch brite. Time to do it again. LOL. | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Eric, I think you are referring to the wheel cylinders. I was wondering about the ID of the master cylinder.
That said, thanks for the info- I didn't realize I could buy WC rebuild kits locally, and for so cheap. Wow! That is good info to have.
Bill | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | inch & 1/8 for the TF master ... should be able to get kits for them at NAPA, whole new masters as well [Raybestos # MC21680], virtually all the TF brake parts are still available from Raybestos, Wagner, Bendix
Bill | | |
