| | | Forums66 Topics128,118 Posts1,056,305 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40811 08/01/2002 6:34 PM | Joined: Jan 2002 Posts: 18 Member | | Member Joined: Jan 2002 Posts: 18 | I have the glass bowl fuel filter on my 235. Does anyone know of a part no. for the paper element that can be purchased at my local parts store. I'm getting tired of ordering them from Danchuck. Thanks. | | |
#40812 08/01/2002 8:10 PM | Joined: Dec 2001 Posts: 43 Member | | Member Joined: Dec 2001 Posts: 43 |
57 3100 235 3 spd
#40813 08/01/2002 8:13 PM | Joined: Dec 2001 Posts: 43 Member | | Member Joined: Dec 2001 Posts: 43 | Anthony, I don't know a part # but I would switch to a plastic filter. I've seen where glass ones have broken while the truck is being driven. Could be dangerous. Just a word of caution.
Andre
P.S. Glad to see you got it running. I guess that manual choke part worked alright.
57 3100 235 3 spd
#40814 08/01/2002 11:34 PM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Well , you can get the glass bowl filter elements at Jim Carters too . Having used the original style filter for 30 years , and had no trouble , I think the broken ones must have been seriously abused . Of course , you choose.  | | |
#40815 08/02/2002 2:51 AM | Joined: Feb 2002 Posts: 24 Apprentice | | Apprentice Joined: Feb 2002 Posts: 24 | If your filter is an AC then the part number is GF 124 (854347) I'm guessing the part in parenthesis is the store's number. I bought it at a Auto Value store, the lady at the counter said they still carry them because alot of tractors use them.
I have a durex glass bowl filter also but this paper filter won't fit it properly.
Hope this helps. | | |
#40816 08/02/2002 5:15 AM | Joined: Mar 2001 Posts: 265 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 265 | Anthony:
I have a Carter fuel filter with glass bowl. I found a paper filter at NAPA, part number 3943. Probably about the same size as yours. It works perfectly. Hope this helps.
Rugo 53 3100 Smokem if you gottem, if you haven't gottem, I know where you can gettem.
Steve Rugg 53 3100
#40817 08/05/2002 1:56 PM | Joined: Jan 2002 Posts: 18 Member | | Member Joined: Jan 2002 Posts: 18 | Thanks guys I'm going to the local Napa today.
Andre thanks for the advice, the choke part worked beatifully. I cleaned it and painted it and now I'm on the road. I now have a complete truck carb and choke system on my 55 car. The manual choke really helped my gas milage. | | |
