0 members (),
90
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 47 | I'm in need of a special application steering connector (Chev Part #6.870) from Pitman arm to steering arm with a ball to ball length of appx, 16 inches. Anyone have an idea..perhaps something from a Big Bolt or COE?Thanks for any help. | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | what year truck do you have ? stock front suspension or lowered ? leonard | | | | | Joined: Sep 2006 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 47 | The vehicle is actually a '35, but the steering box is from a '40 car and is located forward from the original mounting point. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | You could make your own. Just center the steering wheel, point the wheels straight ahead, measure the distance between the pitman arm center and the steering arm. Then take your old drag link to your friendly tig welder and have him work some magic on it. That's what I did, and for $20 I have my "custom" drag link. You can also mix or match the ends this ways too. If you want to get fancy, you could put in an adjustable link. | | | | | Joined: Sep 2006 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 47 | Thanks Waldo. Looks like I may be headed in that direction. | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | ironhead68, as waldo53 suggested, i did the same thing. i needed a shorter drag link after installing a dropped front axle in my 57, so i cut out 1 1/4 of an inch, and tig welded together, even putting a small piece of pipe over the weld joint, and tig welding that also to the rod. here is a pic of mine after modification. http://s251.photobucket.com/albums/...00/?action=view¤t=DSC01379.jpghope this helps.. leonard | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | see tech tip this is a starting point for you and will work after you get the holes resized for modern tie rod ends. this works on any vehicle not just pre or AD rigs. http://www.stovebolt.com/techtips/draglink_adjustable.html
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Feb 2000 Posts: 5,215 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,215 | Jim, since you list part numbers in your techtip, can you give a approx. length of the finished drag link? I need one about 11.75" + or - a bit. Also, was the taper reamer really needed or can they be hand fitted? Joe | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | The original holes of the steering and pitman arms found in the AD's had to be welded up & ''chevy'' taper cut for the modern ball joynts. I had mine done at a 4 wheel shop. I can't say for your truck's front axle pieces if they need this done. there are many ball joynts and sleeves available and all come in various lengths. mine measure out ::: ball joynts are center to thd. end - 3'' & 8.5'' adj. sleeve 4.25'' my overall length is approx 14'' this could go shorter but you could buy two different ball joynts at 5'' and use this same sleeve. see a flaps for more details. happy hunting http://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=24.jpg
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Joe H - I hand fitted mine with out any problems. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
