1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40768 02/10/2004 4:59 PM | Joined: Jul 2003 Posts: 179 Member | | Member Joined: Jul 2003 Posts: 179 | Hi all, A brown suited hero dropped off a fuel cell last night... [img] http://static.summitracing.com/global/images/prod/large/sum-290100.jpg[/img] But I'm confused - he didn't bring any directions - and I'm not sure where all the lines go! Two 8an lines at the pickup - one for fuel delivery - what is the other for - return? The 6an line on the top - this is a vent I assume. I have no idea how to run the lines to make it work properly - any one with experience that can help me out? - Ryan
59 Apache Step 78 El Camino http://www.wsu.edu/~rsain
#40769 02/10/2004 5:31 PM | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | That looks to be the same set up as mine, too bad mines not done yet. Lowers are for supply and return, the upper is a vent. Havent really looked over the sender unit yet but mine appears a little different. The sender is not maked as to which terminal is the ground or to the gauge. Ive got the supply fittings facing to the rear, anybody know if thats correct or not? http://www.imagestation.com/picture/sraid72/p498689a25f00642880258aa00a477269/fb85db 2d.jpg | | |
#40770 02/10/2004 6:07 PM | Joined: Jul 2003 Posts: 179 Member | | Member Joined: Jul 2003 Posts: 179 | Stea,
I figured that's how the fittings were configured.
Now - the delivery (left or right?) goes to the pump. The return? Where do I run that to?
The vent - that should run to below the tank? - is there a specific fitting that needs to go on the end of either the return or vent lines?
The sending unit in mine is a GM 90ohm. I didn't check for markings as to positive and negative.
- Ryan
#40771 02/10/2004 8:56 PM | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | I am planning on using one lower fitting for the supply line and capping the other, dont think you need it unless u need a return line for fuel injection. Im going carb so i wont need it. As far as the vent, i plan on running a line from the fitting to over the side. I will probably keep it up towards the bed and then find some sort of filter to let air and over flow out but not let anything in. | | |
#40772 02/10/2004 9:12 PM | Joined: Jul 2003 Posts: 179 Member | | Member Joined: Jul 2003 Posts: 179 | Stea,
that answers it - the second line will be capped because I'm using a carb not FI.
Thanks!
- Ryan
#40773 02/10/2004 9:16 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Ryan, please keep us posted on how this turns out. I am very interested in doing this also but have been considering making my own stainless steel tank. How much does yours hold? I'd like to have 18-20 gallons if possible. Also, what do you intend to do for a filler neck and where to locate it? I have lots of questions so am very interested in your thoughts. Thanks. | | |
#40774 02/10/2004 9:38 PM | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | 53moneypit brought up an interesting idea. Ive thought about running a filler neck straight up through the bed floor. Ive seen several aluminum set ups that look good. probably wouldnt be to hard to connect the overflow to the filler neck just below the cap. http://thumbs.ebay.com/pict/2459135734.jpg | | |
#40775 02/11/2004 1:26 AM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Ok, I'm a little slow but I figured out what you're doing. It's a gas tank! And not a fuel cell which uses hydrogen or methanol to produce electricity. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#40776 02/11/2004 1:57 AM | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | OK, I might be able to help out with a couple of answers here. Ryan you should run your vent line to the filler neck. Thats where it will work the best. On the sender there should be a screw down connector in the center (hot) and a slip on connector along the edge (ground). You need to run your ground to the frame. The rest of the lines the other folks have you all set there. On you delivery/return look inside the cell and see if one has a pick filter on it that will be delivery. Money pit, I just got done putting a stainless steel cell in my '46 Panel. Its right at 23 gals, I think its 22" X 26" X 10" if I remember right. You can see it here Fuel cell Fuel cell in place Good luck
David Just a firefighter, Cleverly disguised as a responsible adult '46 1/2 T Panel
#40777 02/11/2004 6:18 AM | Joined: Feb 2004 Posts: 85 Member | | Member Joined: Feb 2004 Posts: 85 | Whoa! dude! fuel cells http://auto.howstuffworks.com/fuel-cell1.htm are used on space craft and the international space station, maybe next you could install a carbon dioxide removal apparatus! What you got there is yer GAS TANK man! PEACE! just as my buddies in England would say, "takin the [censored] outta ya". Aloha!!! | | |
#40778 02/11/2004 7:18 AM | Joined: Jan 2004 Posts: 27 Junior Member | | Junior Member Joined: Jan 2004 Posts: 27 | I guess some of you farmers may not know this, but over at Speedway they call those thingys "bottom sump FUEL CELLS" http://www.speedwaymotors.com They also call them the same thing over at Jeg's and also at Summit. :rolleyes: | | |
#40779 02/11/2004 7:35 AM | Joined: Feb 2004 Posts: 85 Member | | Member Joined: Feb 2004 Posts: 85 | It's all good, this "old farmers" fingerprints are on the "international space station" as an aerospace worker for the past 15 years so sorry, the term just seemed weird to me, it's all about semantic's I quess, YEE HAA!!! | | |
#40780 02/11/2004 4:57 PM | Joined: Jul 2003 Posts: 179 Member | | Member Joined: Jul 2003 Posts: 179 | LOL and Thanks!
Fuel Cells - not the hydrogen powered kind. The gasoline kind. Funny story - nearly all the searches I did on google ended up giving me info for the hydrogen fuel cell.
Seems like replacement gas tanks are called fuel cells and originals are called gas tanks - can't seem to figure any other reason!
Filler neck question: will run directly through the center of the bed - with one of those polished aluminum doors.
I'll be detailing the process on my web page.
- Ryan
#40781 02/11/2004 6:47 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | If using mechanical pump, cap return line off. If using an electric fuel pump, I strongly suggest mounting pump near tank, and running a bypass style regulator that uses the return line for overpressure relief. It'll provide accurate fuel pressure independant of demand and long pump life. Using no fuel pressure regulator or a "deadhead" regulator with no return line usually causes fuel delivery issues and shortened pump life.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#40782 02/11/2004 9:34 PM | Joined: Jul 2003 Posts: 179 Member | | Member Joined: Jul 2003 Posts: 179 | Thanks for the advice - I'll be using a mechanical right now - but in the future....who knows!
- Ryan
#40783 02/12/2004 12:18 AM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Ryan et al, Automotive fuel cells have been mandatory in many racing organizations for years. Using a fuel cell in your old pickemup is actually a darn good idea. Automotive Fuel Cell
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
