| | | Forums66 Topics128,162 Posts1,057,065 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | What are those knarly little gizmo's that are sometimes attached to intake manifolds? It looks like an old grease cup, but it is inline with the vacuum line from the manifold.
Is it a check valve or filter of some sort?
Thanks, | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Well Bill, those are the optional Knarly Little Gizmos. Sort of rare these days I think. Seldom seen so I'm sure many of us would appreciate a picture. | | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | I should have included something in the picture for scale. The top is only slightly bigger around than a quarter. | | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | Does it rattle like a pcv valve? | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Bill - That is your "vacuum tank" for the windshield wipers. Those items are difficult to find as they tend to rust quickly or disappear for whatever reason. Consequently they are not seen or used that much. Instead a brass fitting is used in it's place and it will also work to propel the wipers. This little tank, however, actually stores up a small amount of vacuum to keep the wipers more steady during a driving in a rain event. I have often thought that a larger vacuum tank would work even better, but our engines apparently do not produce enough vacuum to store a large amount. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | Joe,
Thanks. I guess it can't hurt to clean it up and stick it on the manifold. I don't plan to drive much in the rain and since the truck isn't finished, it won't be out in the rain for some time.
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I think that would be better than just plugging the hole. My Edelbrock has two vaccum holes on it, so I block that front one and use another on top behind the rear carb, but I might take it "up front" for looks. I had mine chromed some years back. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I think it's a check valve or "anti backfire valve". It's very similar in size and design to the ones used on vacuum brake boosters. The ones on a booster protect the diaphram and the one in the wiper line could stop the violent snap back the wipers do when the engine backfires. The vacuum chamber inside the motor is 4 or 5 times as large as this item so it wouldn't have enough reserve to even make a partial swing.
Evan
