1 members (Peggy M),
121
Mod | | | Forums66 Topics128,072 Posts1,055,904 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 102 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 102 | Hi Guys...been hanging out in Mexico while the burbs asleep for our Canadian winter.
Found a very cool chrome dash mount repro truck fan. It's been set up with a two speed motor worked by a switch on the fan itself and a wire with the cig lite plug in.
Can this be hard wired?
eb's 63 | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If by hard wired you mean connected to work off of a switch in/on the dash the answer is yes. If you mean to bypass the cigarette lighter plug-in, wiring it directly to the harness, but still operate it using the built in switch the answer is also yes.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Eb,
I agree with what Tiny has said, but interpret your question a little differently. If the two speed switch is part of the fan/motor, then you would merely take the wire that plugs into the cigarette lighter and wire it into a switched connection somewhere.
Does a '63 have a fuse box? Are there one or two spare tabs that switched ON with the key. Couldn't you stick your fan on one of these.
I would guess you want this thing off when you turn the key OFF. However you decide to do it, make sure you have a proper fuse in the circuit.
Stuart | | | | | Joined: Nov 2006 Posts: 102 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 102 | Thanks guys...will let you know how it works out when I get back to working on the burb. I am building a 1962, 283 and have a custom complete wiring harness ( from Brothers )including fuse box. So the fan, conversion to 2 speed wiper set the new cig lighter and a bunch of electrical problem stuff should get sorted out. Thanks again
eb | | |
