1 members (dt235sd), 61 guests, and 0 robots.
Topics128,049
Posts1,055,740
#407197 04/27/2008 8:11 PM
Hi Guys...been hanging out in Mexico while the burbs asleep for our Canadian winter.
Found a very cool chrome dash mount repro truck fan. It's been set up with a two speed motor worked by a switch on the fan itself and a wire with the cig lite plug in.
Can this be hard wired?
eb's 63
Ex Hall Monitor
Ex Hall Monitor
If by hard wired you mean connected to work off of a switch in/on the dash the answer is yes. If you mean to bypass the cigarette lighter plug-in, wiring it directly to the harness, but still operate it using the built in switch the answer is also yes.
Tiny #407238 04/27/2008 10:14 PM
Eb,
I agree with what Tiny has said, but interpret your question a little differently. If the two speed switch is part of the fan/motor, then you would merely take the wire that plugs into the cigarette lighter and wire it into a switched connection somewhere.
Does a '63 have a fuse box? Are there one or two spare tabs that switched ON with the key. Couldn't you stick your fan on one of these.
I would guess you want this thing off when you turn the key OFF. However you decide to do it, make sure you have a proper fuse in the circuit.
Stuart
Thanks guys...will let you know how it works out when I get back to working on the burb. I am building a 1962, 283 and have a custom complete wiring harness ( from Brothers )including fuse box. So the fan, conversion to 2 speed wiper set the new cig lighter and a bunch of electrical problem stuff should get sorted out.
Thanks again
eb
