| | | Forums66 Topics128,089 Posts1,056,437 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 16 Apprentice | | Apprentice Joined: Mar 2003 Posts: 16 | hey guys i am putting my 53 1/2 ton truck back together and i have run into a snag. will a dual offenhauser intake with column shift work. i have cut my steering column to use with a power steering setup so im not sure where the column is supposed to sit. It looks like the shifter arms are going to hit the intake. anyone have this setup with some pictures i could go on? thanks
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 |
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Curt B.,
Does your set up have the original steering column?
If yes, did you lengthen the "arms" in order to clear the Fenton intake?
Are the Fenton and Offenhauser intakes the same in terms of shifter-clearance?
I am asking these questions because I will have the choice of a Fenton or an Offenhauser intake for use in an otherwise stock 1/2 ton 1954 truck.
Thanks, Tim | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Tim, The answers to your first 2 questions are yes and yes. I have heard some have shortened the arms to clear but the throw would become short as well so I don't know how well that works. I would guess the interference would be about the same. As for intake choice the carbs are 9" apart on the Offy and 11" on the Fenton so your choice of air cleaners may be a consideration. I experimented with a few different arm lengths and geometries until I was happy with the throw.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Mar 2003 Posts: 16 Apprentice | | Apprentice Joined: Mar 2003 Posts: 16 | hey curt. thanks for the picture. i got another look at it today and it will definatly not work stock soooo i figured would have to do some modifications. what you did looks great.
| | | | | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | I had Offy dual carb intake on my 54 when it had three speed on the column and had no claearnce problems. However, the only exhaust that has been on the truck was a Corvette split manifold and later, a set of Clifford long tube headers. [IMG]http://thumb17.webshots.net/t/69/69/0/22/89/2922022890047579877PysoHd_th.jpg[/IMG]I also had to remove the driver's side firewall to fender brace. | | |
