| | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 25 Apprentice | | Apprentice Joined: May 2007 Posts: 25 | On my 53 Chev I put new 12v headlight plugs, can anyone tell me what termial is for the high beam,low beam and ground? | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | looking from the rear of the plug, ground is to the left high beam to the right low beam on top | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | If you have an ohmmeter then here's the way. Let's name the three terminals on the diconnected headlight A,B,and C. You are going to measure small amounts of resistance so use a good ohmmeter. Measure each terminal to the others...AB=?ohms, AC=?ohms, BC=?ohms. The largest ohm reading, say AB=6ohms identifies the hi/low terminals. The next highest reading, say AC=4ohms is your low beam. The lowest ohm reading, say BC=2ohms is your high beam. The C terminal is ground. Good luck
