1 members (Ridgeback), 42 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#406403 04/25/2008 6:18 AM
Apprentice
Apprentice
On my 53 Chev I put new 12v headlight plugs, can anyone tell me what termial is for the high beam,low beam and ground?
looking from the rear of the plug,
ground is to the left
high beam to the right
low beam on top
1952 Chevy Shortbed
Photos in Photobucket
If you have an ohmmeter then here's the way. Let's name the three terminals on the diconnected headlight A,B,and C. You are going to measure small amounts of resistance so use a good ohmmeter. Measure each terminal to the others...AB=?ohms, AC=?ohms, BC=?ohms. The largest ohm reading, say AB=6ohms identifies the hi/low terminals. The next highest reading, say AC=4ohms is your low beam. The lowest ohm reading, say BC=2ohms is your high beam. The C terminal is ground. Good luck
