8 members (Mike B, WICruiser, Youngin' Tut 59, Pete1946, Bizaircon, klhansen, LuckyLee, 1 invisible),
72
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,140 Posts1,056,770 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | My 59 3100 has been repainted and when I look at the underhood firewall cowl I see the usual holes for the main harness and the speedometer etc. I am perplexed by the factory manual showing the speedomter cable route through the rubber grommet a bit offset from center, while there is a similar sized hole with two small holes (one above and below) it. It appears to be a`real factory hole used to attach something or other but the manual does not show anything. Any of you have the answer? I would be glad to send you a photo if need be. I am wondering why the speedo cable does not go through this opening. Thanks | | | | | Joined: Aug 2005 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 113 | rasman, I'm not sure if this will help you, but here's a pic of my '59 3100 when I purchased it. http://rides.webshots.com/photo/2374642770098190200VyHPdVThere are a few more pics in my albums that you may want to check out. I'm not sure if it will make a difference, but they are Canadian trucks. I'm sure someone else has some better pics for you. Lane | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Rasman - here's a pic, close to correct original except the 4hole grommet for the main harness should be a single hole ... remember that there was various equipment that provisions were left for, even if your truck didn't have them, one of the things that comes out the same hole as the speedo cable is the hand throttle, missing in my picture, also there was the wiper vacuum hose and a windshield washer hose, and,and,and Bill | | | | | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | Thanks guys. Makes sense. I see the same hole in Bill's that I was wondering about just below the speedo cable. I bet the hand throttle fits there after you mentioned it as it would seem to fit. I appreciate the help and good reference photos | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | That's a good picture, Bill. Thanks for posting it. I have some grommet things to tighten up and will use your photo as a go-by.
Bill | | |
