2 members (Hotrod Lincoln, Stewart2), 125 guests, and 1 robot.
Topics128,195
Posts1,057,372
Members48,469
I have a 1951 Chev 1/2-ton pickup that has a 350 in it with a muncie 4-speed. I have the smaller clutch/153-tooth flywheel, and changing it to the larger 12-inch clutch and the 168-tooth flywheel, and bell housing as well. Now I have fabricated the old 6-cylinder drive train linkage stuff that works the V8 thats in there now...meaning clutch linkage set-up. What I'd like to know, is there a nicer set-up for linkage change over to the v8 with the stock pedal(s) assembly? Other linkage from...or what else works? The way it is now, is kind of scabbed together, but works fine. But I want to change it right. And I did this back in 1980 when I put in a small block engine. Need help! Got any ideas? Much appreciated it so. Thanks, Diditanole
I thought this was pretty inventive and might give you some ideas:
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=5A.jpg
You Tube
Curt B; I like that clutch linkage set-up...pic. Who fabricates these, and sells them? Would like to purchase one if so. Please let me know. And looking at the pic, it looks like it would work fine in my '51 Chev. And yes, it looks clean too. Sweet set-up! Thanks for your help Shop Shark! Much appreciated! ...Diditanole
this was made to fit my vehicle as all bolts are not the same.
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=9A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=8A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=7A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=6A.jpg
The different angles may make it easier to fab one up. made this to work w/ my 292 installed in my 51 3104 and
a T5 hybrid (camaro gutz+S10 housing) tranny, so i could use all stock pedals
also used a mr gasket bell crank for the throttle using the stock pedal to a lokar cable to an edelbrock 500. Along w/ this is an early
corvette clutch arm 53-58 only so we could get the clearance we needed because of the location of the 292 in situ.
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=Scan1_0001.jpg
Jim & Caroline
I don't think anybody does but it looks like Jim has documented what he did well enough that you could make something similar for your application.
Jim,
Nice clean engineering and work you've done. Hope you don't mind me posting a link to your pic's.
Curt B.
You Tube
Hey Curt
No problems here ... that's what this is all about helping fellow bolters out . I was kind of shocked to even see that somebody knew what I had done. I think its fun to document these things we are the temporary owners of ''our bolts'' & let other see them who may be so far away.
carry on my friend wink
Jim & Caroline
It sure would be nice if someone out there fabricates these and sells them! The clutch linkage set-up (with the "STOCK" foot pedals) to the small-block 350 in my 1951 1/2-ton P/U. I'm hoping that someone would come forward with knowledge of finding one of these. Otherwise, I'll just keep looking. I guess that you could say...wait and see, huh? Thanks for all the info...diditanole
someone has........................... smile
'''''this was made to fit my vehicle as all ''bolts'' are not the same. ...... The different angles may make it easier to fab one up. made this to work w/ my 292 installed in my 51 3104 ''''' and a T5 hybrid (camaro gutz+S10 housing) tranny, so i could use all stock pedals.
also used a mr gasket bell crank for the throttle using the stock pedal to a lokar cable to an edelbrock 500. Along w/ this is an early corvette clutch arm 53-58 only so we could
get the clearance we needed because of the location of the 292 in situ.''''''
big_eekThis fixture may not work w/ your 350 because of different angles. You'll have to fab your own so it fits your bolt.
Jim & Caroline
Thanks shop shark! ...diditanole
[b]1957 Chevy Big Window 3100[.b]
More pix in Picasa
It ain't broke 'til you can't fix it any more.
Thanks, diditanole
