2 members (55shaker, Steelonsteel), 117 guests, and 4 robots.
Topics128,126
Posts1,056,354
Members48,441
#406043 04/24/2008 6:23 AM
U
U Offline
I would like to post a warning regarding the TCI Mustang 11 front end. This is the situation with my truck, may not be the same for everyone but I think it would be. The reason I went for this frontend in the first place was because it was being done at home and I did not want to sart remounting the front sheet metal. My truck has a TCI premium (welds are dressed back) mustang 11 suspension supplied by them thru a dealer here in Oz . Kit came with Heidts instructions??. Suspension was installed fairly straight forward operation. Modifications are needed to be made to the inner fenders for clearance around the shocker tower again no problem. I also removed the inner fender to firewall braces/struts whatever they are called, by making body adjusters that are fixed from the chassis to the lower radiator support to inner fender bolts, making the engine bay cleaner. I was not overly impressed with the handing so I ordered a swaybar to suit. This did not fit on my frontend as there was no integral mounting for the sway bar, on questioning TCI why this is so the answer was " you must have an early frontend just weld on some mounts ". I was not impressed with this as I had spent quite a large sum of money getting this unit to australia. So until recently still had no swaybar and the handling is crap. So I ordered some polished stainless steel upper and lower control arms again thru same dealer and again thru TCI. Theory being a fresh shiny update and a swaybar that fits.
How wrong could I be!! After installing the lower control arms which is a pain with the ball joints as you are aware. lo and behold my wheelbase has been shortened 20mm #$%@%^&* whats with that??? also swaybar does not fit as it hits the lower reinforcing plate of the shocker #$%^%^&* again what's with that ???
On further investigation TCI sold me a universal stainless steel kit which maybe ok on your belly button hotrods i.e red 32 roadsters and the like but not on trucks with there supplied swaybar.
So at the moment I have very expensive garage wallpaper in the form of polished stainless steel control arms. I am out of pocket upto $2000.00+ and what do I get from TCI NOTHING, NO RESPONSE to EMAILS only the sound of silence
BUYER BEWARE
usa050aus #406199 04/24/2008 8:44 PM
Seeing as how this guy wants to bash TCI,I will; post my experience with them. I bought the M2 frontend from them about 5 yrs. ago.It was a fairly easy install,however you do need to read the instruction sheet prepared by TCI,and Oh yeah measure everything up several times before you start welding the crossmember in.Just to make darn sure everything is AOK.At the time I ordered this unit I ordered it with the regular control arms.While my order was being processed they stopped using the regular arms,and I recieved the tubular A arms at the same cost as the regulars.Only one problem hooking up the power steering,and I sent them an Email,which they answered right back.Informing me that if I use a GM pump with the TBird rack that they use I will blow the seals.The dealer who I ordered it thru gave me a pressure reduction valve for my GM pump.The old 55 drives and handles like a new truck,no problems whatsoever.Two yrs. ago I bought the rear suspension package from TCI,which included new 5 leaf springs,spring hangers,shackles ,shocks,shock mounts.spring perches for the rearend,etc.Another easy install and no problems whatsoever.If I ever decide to do another build it will be with TCI products.
dale937 #406774 04/26/2008 10:32 AM
U
U Offline
TCI have responded with an email hopefully with an attempt to sort out my problem. I will keep stovebolt posted and will be the first to submit a retraction when a satisfactory conclusion is reached.
