4 members (Eisenholtz, baldeagle, NJC, Southerntruck), 165 guests, and 2 robots.
Topics128,037
Posts1,055,468
Members48,424
#40595 06/21/2004 3:32 AM
Junior Member
Junior Member
Let me start by saying I've probably changed my oil 100 times. Today I went to take the oil filter off my 70 chevy, and it won't budge. I've tried a filter wrench, strap wrench, and finally the screw driver through the filter, no luck. Any suggestions before I call a tow truck to have it taken to a shop.
#40596 06/21/2004 3:14 PM
Rip off the filter shell and remove the filter element, use a hacksaw and/or grinder to cut two nipples in the end of a suitable diameter pipe to go in the holes of the filter plate and use a pipe wrench to turn the pipe. Good luck.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
#40597 06/21/2004 5:59 PM
Do you have access to an air hammer?
If not use a lage hammer3 to 4 lb. and a punch to tap (hammer, pound etc,,,) on the base of the filter in the direction you need to remove it.
#40598 06/22/2004 3:53 AM
Get the shell and insides of the filter off. Then take large needle nose pliers and insert them into the filter flange holes. Take a large screwdriver and insert it into the jaws of the pliers and turn. It's a poor mans spanner wrench. Next, lube new filter with grease instead of oil.
Good luck which ever way you do it,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#40599 06/23/2004 3:11 AM
Scott, did you ever get the filter off your motor? Or did you have to rip the motor off of the filter. :p
#40600 06/23/2004 2:11 PM
Ooops sorry, I didn't read that you've already tried the strap wrench. eek
[img]http://www.harborfreight.com/cpi/photos//46300-46399/46392-t.gif[/img]
#40601 06/24/2004 5:48 PM
Don't use grease!!! Over time it acts like glue when it gets hard.Just use a sufficient amout if oil on the seal. Then, hand tighten the filter. Do not use a wrench to tighten the filter!!! I've experienced several nightmares when grease was used on the filter seal.
JS
"I can go anywhere...for I am a Piewagoneer...To the Piewagon"
1966 Chevy Panel Delivery 1966 in the Gallery and more on Webshots
