Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Gdads51, ShopRag, baldeagle, Southerntruck, Otto Skorzeny, HandyAndy), 51 guests, and 1 robot.
Topics128,008
Posts1,055,285
Members48,418
#405611 04/23/2008 3:24 AM
has anyone boxed the frame on their AD? the frame seems a little weak. I boxed the front for the Mustang II suspension and now I think I will continue it to the rear. anyone done this or have pictures?
1950 custom streetrod build
http://67-72chevytrucks.com/vboard/showthread.php?t=296770
71 corvette conv, 525 hp big block
50adrod #405622 04/23/2008 3:59 AM
Probably not necessary unless you're running a tremendous amount of horsepower. The frame isn't really weak if its in good condition. The metal is thicker and there is more of it than many more recent cars and trucks in similar weight class.
People have done it, and one solution I though interesting was to use the sides of a spare frame to provide the fourth side.
OldSub #405698 04/23/2008 12:18 PM
i will have around 350 hp. in the process of installing the rear suspension I removed the rear crossmember. I know this adds strength. but with it out you can twist the frame by hand and it is in good shape. I will replace the rear crossmember with a piece of tubing and fab up a hidden reciever hitch.
OldSub #405701 04/23/2008 12:32 PM
Boxing a frame is probably the most common thing done with a old frame to ensure it holds up to the stresses applied to it by upgrading motors, suspensions, and running gear in general. The "hotrod" and "streetrod" mags are full of this kind of information. If your truck is exploded to the point where it's nothing but material and time to make it happen then I would go for it. It sure can't hurt. Check out the old mags on this kind of project as they give many helpful insights into the little tricks like welding in nuts and mounting plates to make reassembly easier. Good luck.
beltfed #405704 04/23/2008 12:56 PM
I boxed the frame where the sub frame attached and the c-notch in the rear. Can't get any traction, so frame flex isn't a problem.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
wilbur #405712 04/23/2008 1:17 PM
do you have any pictures of the frame?
50adrod #405770 04/23/2008 5:26 PM
"A sticth in time saves nine". Poor Richard's almanac.
~Jim
My frame's boxed front to rear. The chassis was down to bare bones so I didn't think it would hurt.
S'pose I'll need to wait untill I drive it to see if it's made any difference!
More pix on Flickr.
