1 members (55shaker),
42
Mod | | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | has anyone boxed the frame on their AD? the frame seems a little weak. I boxed the front for the Mustang II suspension and now I think I will continue it to the rear. anyone done this or have pictures? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Probably not necessary unless you're running a tremendous amount of horsepower. The frame isn't really weak if its in good condition. The metal is thicker and there is more of it than many more recent cars and trucks in similar weight class.
People have done it, and one solution I though interesting was to use the sides of a spare frame to provide the fourth side.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | Probably not necessary unless you're running a tremendous amount of horsepower. The frame isn't really weak if its in good condition. The metal is thicker and there is more of it than many more recent cars and trucks in similar weight class.
People have done it, and one solution I though interesting was to use the sides of a spare frame to provide the fourth side. i will have around 350 hp. in the process of installing the rear suspension I removed the rear crossmember. I know this adds strength. but with it out you can twist the frame by hand and it is in good shape. I will replace the rear crossmember with a piece of tubing and fab up a hidden reciever hitch. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Boxing a frame is probably the most common thing done with a old frame to ensure it holds up to the stresses applied to it by upgrading motors, suspensions, and running gear in general. The "hotrod" and "streetrod" mags are full of this kind of information. If your truck is exploded to the point where it's nothing but material and time to make it happen then I would go for it. It sure can't hurt. Check out the old mags on this kind of project as they give many helpful insights into the little tricks like welding in nuts and mounting plates to make reassembly easier. Good luck.
| | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | I boxed the frame where the sub frame attached and the c-notch in the rear. Can't get any traction, so frame flex isn't a problem. | | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | I boxed the frame where the sub frame attached and the c-notch in the rear. Can't get any traction, so frame flex isn't a problem. do you have any pictures of the frame? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | "A sticth in time saves nine". Poor Richard's almanac.
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | My frame's boxed front to rear. The chassis was down to bare bones so I didn't think it would hurt. S'pose I'll need to wait untill I drive it to see if it's made any difference! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
