Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (Rnl364, baldeagle), 50 guests, and 1 robot.
Topics128,004
Posts1,055,246
Members48,418
I was under the Burb cleaning the frame and preparing to install a set of monoleaf springs this weekend. Got the drivers side spring out without too much of a problem although one of the shackle bolts caused me some trouble. Problem is on the passenger side I can't get the pin out of the front casting. When I got to looking at it real close I can see the casting is all wallowed out where the pin fits through. So the pin is frozen on the spring and the casting is damaged.
Any advice on what to do? I need to either repair or replace the casting so I think I should cut off the rivets and then worry about getting the the pin and spring off later, right? Can the casting be welded or will I need to overbore and bush it? Will grade 8 hardware keep the casting in place when I'm done?
Plan B is to sell the monleafs and go for a 4 link.
By the way I thought I read somewhere that the 1/2 ton has 7 leafs on the rear. The Burb has 9 leafs hanging a 67 truck 12 bolt. Was the 9 leaf spring an option for a 58 or did the PO make the mod when the rear end was swapped?
Apprentice
Apprentice
Mr. Dburb
I ran into the same problem with both of my rear springs, everything was oval. I replaced the cast parts and new springs. To hold them on I used grade 8 button head bolts. They look like rivits except for the place the allen wrench fits.
Now, rivits should be used since all the space is taken up when they are smashed, and no chance for movemet.
Most of us do not use our trucks for daily drivers, I dont, and have not had any problems.
If you use your truck frequently you could check the torque on the nuts, but I think you find they will work for you.
Jim
Thanks Jim. Hadn't thought about the size or style of bolt yet. I see the Burb making runs to the hardware store/lumber yard and general weekend chores but not regular daily use.
