| | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 58 | I was under the Burb cleaning the frame and preparing to install a set of monoleaf springs this weekend. Got the drivers side spring out without too much of a problem although one of the shackle bolts caused me some trouble. Problem is on the passenger side I can't get the pin out of the front casting. When I got to looking at it real close I can see the casting is all wallowed out where the pin fits through. So the pin is frozen on the spring and the casting is damaged.
Any advice on what to do? I need to either repair or replace the casting so I think I should cut off the rivets and then worry about getting the the pin and spring off later, right? Can the casting be welded or will I need to overbore and bush it? Will grade 8 hardware keep the casting in place when I'm done?
Plan B is to sell the monleafs and go for a 4 link.
By the way I thought I read somewhere that the 1/2 ton has 7 leafs on the rear. The Burb has 9 leafs hanging a 67 truck 12 bolt. Was the 9 leaf spring an option for a 58 or did the PO make the mod when the rear end was swapped? | | | | | Joined: Jul 2003 Posts: 38 Apprentice | | Apprentice Joined: Jul 2003 Posts: 38 | Mr. Dburb
I ran into the same problem with both of my rear springs, everything was oval. I replaced the cast parts and new springs. To hold them on I used grade 8 button head bolts. They look like rivits except for the place the allen wrench fits.
Now, rivits should be used since all the space is taken up when they are smashed, and no chance for movemet.
Most of us do not use our trucks for daily drivers, I dont, and have not had any problems.
If you use your truck frequently you could check the torque on the nuts, but I think you find they will work for you.
Jim
| | | | | Joined: Oct 2007 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 58 | Thanks Jim. Hadn't thought about the size or style of bolt yet. I see the Burb making runs to the hardware store/lumber yard and general weekend chores but not regular daily use. | | |
