0 members (), 120 guests, and 4 robots.
Topics128,184
Posts1,057,266
Members48,467
Hi,
This is for the 60-66 guys, on the cab I want to switch to which is stripped out and primed.
(this pic shows sripped cab and seam in the upper left roof area)
http://rides.webshots.com/photo/1418342078054402330ovysKb
There are a few seams that I don't know how to deal with? If you look at the cab from the outside front you will notice a seam above the window to each side under the lip of the roof.
Since I had the cab dipped, this cleaned out any and all bondo, seam filler etc.
Has anyone dealth with this issue before? I uess I could fill it with bondo, oe do you use a seam filler/sealer, Does anyone know what was used?
Also on this area would I use Metal to metal filler or regular bondo?
http://rides.webshots.com/photo/1418654689054402330xRhAsN
Jake
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
Nice 1800 ! I have a 72 1800E
Clem
59 Chevy 3600
New Hampshire
You could just fill that old body damage with any plastic body filler,BUT if it was mine I would hammer & dolly the metal out a little better first. It just depends on how much filler you want in it & how much time you want to spend on it.It looks like someone stretched the metal pretty good by not properly working the metal out and hid the evil deed with body filler.
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
Alan, In the first pictures what do you think I can so with the roof seam?
I would think you would want to lead those seams given their proximity to the windshield gasket, but I've never worked on that year of cab. What filled the seams on your old cab?
Paint & Body Shop moderator
I guess something factory added, I can't tell on the other cab. BTW can someone post the link to the tech tips on filling seams from martin senior, I can't seem to find it.
jake
cuz yer not using the right name, it's MARTINSR, as in Martin-Senour paint grin .... article at the auto body store
It probably was filled with lead from the factory. I am not sure if it was smooth across the top or if it had that seam showing. My 57 is smooth at the seam & is filled with lead. I am replacing part of my roof and am going to use plastic filler in place of lead.
Thanks Red58
I ain't fooling with the lead, Would it be Ok to use Metal to Metal, or stick with the plastic filler?
Jake
