0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Hi, This is for the 60-66 guys, on the cab I want to switch to which is stripped out and primed. (this pic shows sripped cab and seam in the upper left roof area) http://rides.webshots.com/photo/1418342078054402330ovysKbThere are a few seams that I don't know how to deal with? If you look at the cab from the outside front you will notice a seam above the window to each side under the lip of the roof. Since I had the cab dipped, this cleaned out any and all bondo, seam filler etc. Has anyone dealth with this issue before? I uess I could fill it with bondo, oe do you use a seam filler/sealer, Does anyone know what was used? Also on this area would I use Metal to metal filler or regular bondo? http://rides.webshots.com/photo/1418654689054402330xRhAsNThanks Jake | | | | | Joined: Mar 2002 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 53 | Nice 1800 ! I have a 72 1800E
Clem 59 Chevy 3600 New Hampshire
| | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | You could just fill that old body damage with any plastic body filler,BUT if it was mine I would hammer & dolly the metal out a little better first. It just depends on how much filler you want in it & how much time you want to spend on it.It looks like someone stretched the metal pretty good by not properly working the metal out and hid the evil deed with body filler. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Alan, In the first pictures what do you think I can so with the roof seam?
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I would think you would want to lead those seams given their proximity to the windshield gasket, but I've never worked on that year of cab. What filled the seams on your old cab?
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I guess something factory added, I can't tell on the other cab. BTW can someone post the link to the tech tips on filling seams from martin senior, I can't seem to find it. Thanks
jake | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | cuz yer not using the right name, it's MARTINSR, as in Martin-Senour paint  .... article at the auto body storeBill | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | Alan, In the first pictures what do you think I can so with the roof seam? It probably was filled with lead from the factory. I am not sure if it was smooth across the top or if it had that seam showing. My 57 is smooth at the seam & is filled with lead. I am replacing part of my roof and am going to use plastic filler in place of lead. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Thanks Red58
I ain't fooling with the lead, Would it be Ok to use Metal to Metal, or stick with the plastic filler?
Jake
