| | | Forums66 Topics128,191 Posts1,057,362 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 136 | Hello everyone -
I am doing some planning for when I install an IFS in the next month and I could really use some advice. (55 2nd series 1/2 ton)
From what I have read in past threads, it sounds like I should wait to purchase and install the steering column until after I get the IFS, the motor and the tranny in place. This way I can get the correct length column and to see what is really needed to get it hooked up right.
What do you all think? Am I on the right track?
Thanks!
Ross
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Sounds like a plan.
Even if you use your original column, like I did, you need to wait till you get the steering gear box mounted before ordering the shaft and u-joints. Probably also a good idea to wait on installing the column till engine is in place, as you may need to change where it exits the cab slightly if it interferes with stuff.
Grigg | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | What Grigg said ..and I suggest this also if you are purchasing a new steering columm this is the time to do some measurin to get the wheel where you want it, the PO put mine in he musta been a SLIM JIM ..the wheel is back way to far an in my chest,THANK GOD ITS A TILT WHEEL! but that is a project for next year as the wife is abought at the end as far as patience on my project agains the house projects ...lol | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | You are right on track.When I did my 55 2nd series,I waited til it was all back together,then measured things up and bought a Billet specialtie steering column,and Borgenson joints and shaft.Things went together AOK.I now have a 65 Chevy pickup that someone screwed up the steering column. I am gonna take it out and visit the local salvage yard and put in a late model tilt column. | | | | | Joined: Jan 2007 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 136 | Thanks for the support.
I just got done taking out the old steering column, shift linkage and steering box.
Everything went smooth. I was also able to get the brakes disconnected.
Now I have to figure out how to remove the front end (leaf springs, axle etc.) so I can get it cleaned up and ready for the IFS.
Ross | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Ross The advice given is correct. The reason your IFS needs to be in place when you set your steering is because the IFS cannot be adjusted; it must be where it must be. With the steering shaft joints you will be using the shaft can be moved to accommodate the steer box.
~Jim
