| | | Forums66 Topics128,014 Posts1,055,333 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | BIG,
Did you mean to write .010. The figure you posted, .001 is only a hair oversize and would, or should easily tap in...you must have meant .010, which is ten thousandths and could make it a no-go.
Stuart | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | A little file work and some frequent measuring should make things fit. One or two thousandths over the size of the hole in the block should be just about right for a tight tap-in fit. If you taper the dipstick tube so the first 2/3 of the block contact area drops in, the last 1/2" or so is all that really needs to fit tight. A snug slip fit and a drop of red LocTite works, too. Jerry
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | The original is .368 and the Lokar is .369. Are you saying that is just only one thousandths difference? I am just afraid if I try to force it into the block it will go a few inches and get stuck. I have tried tapping it with medium strength taps but it won't go more than half an inch. I tappered the end somewhat but that didn't seem to help any.
~Jim
| | | | | Joined: Mar 2008 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 43 | Emory cloth will do the trick if it is that little difference.
Spencer | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | BIG, As they used to say on Laugh-In...you bet your bippy! Three hundred and sixty eight thousandths PLUS one thousandth is...three hundred and sixty nine thousandths.  Stuart | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I guess I'll try the Emory cloth approach and see if that will work.
~Jim
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Well the problem I have discovered, after reducing the dia. 1.5 thousandths, was the header was in the way and after unscrewing the bottom half of the dipstick she slid right in.
~Jim
