5 members (baldeagle, Gray_Ghost, Forty9, Hush, tclederman), 56 guests, and 7 robots.
Topics128,020
Posts1,055,345
Members48,419
#404358 04/20/2008 2:02 AM
I bought a Lokar billet dipstick for my crate engine to replace the stock dipstick. Try as I might, I could not get the tube to insert into the block. I measured each and the lokar is .0010 larger in diameter than the stock. It is the correct product for a 350 passenger side. Is there a trick short of boring to get the thing in there? headscratch
http://good-times.webshots.com/photo/2780315160099708909UIiKsd
http://good-times.webshots.com/photo/2116725430099708909FtMEip
~Jim
BIG,
Did you mean to write .010. The figure you posted, .001 is only a hair oversize and would, or should easily tap in...you must have meant .010, which is ten thousandths and could make it a no-go.
Stuart
atomarc #404369 04/20/2008 2:20 AM
A little file work and some frequent measuring should make things fit. One or two thousandths over the size of the hole in the block should be just about right for a tight tap-in fit. If you taper the dipstick tube so the first 2/3 of the block contact area drops in, the last 1/2" or so is all that really needs to fit tight. A snug slip fit and a drop of red LocTite works, too.
The original is .368 and the Lokar is .369. Are you saying that is just only one thousandths difference?
I am just afraid if I try to force it into the block it will go a few inches and get stuck. I have tried tapping it with medium strength taps but it won't go more than half an inch. I tappered the end somewhat but that didn't seem to help any.
~Jim
Emory cloth will do the trick if it is that little difference.
Spencer
BIG,
As they used to say on Laugh-In...you bet your bippy! Three hundred and sixty eight thousandths PLUS one thousandth is...three hundred and sixty nine thousandths. wave
Stuart
atomarc #404397 04/20/2008 3:13 AM
I guess I'll try the Emory cloth approach and see if that will work.
~Jim
Well the problem I have discovered, after reducing the dia. 1.5 thousandths, was the header was in the way and after unscrewing the bottom half of the dipstick she slid right in.
~Jim
