5 members (Otto Skorzeny, TooMany2count, Eisenholtz, Shardean, Gdads51), 58 guests, and 3 robots.
Topics128,023
Posts1,055,366
Members48,420
#402936 04/16/2008 2:08 PM
V
V Offline
Does anyone know if there is a patch panel sold for the front fender, 47/53 BOTTOM LOWER FRONT AREA? I did find some for the rear fenders.
no luck here, looked in my many catalogs.
Sorry
1952 Chevy Shortbed
Photos in Photobucket
All the lower front part of the fenders are the same from '47-54 as long as you don't go up to high. The '54 had a difference how the grill mounted and the parking light area. Find a good used fender and hackout the piece you need.
Bruce
My Trucks
Stuff I Collect
I have searched and searched and decided I will just replace the fender. I'm kind of surprised that they aren't available since most I have found are rusted out in the same place as mine.
Don't give up looking just yet. While the big vendors might not carry it you might run across someone that makes them himself. Do a search here on the Bolt. A year or two ago the subject was covered and there was a guy that had a shop that specialized in sheetmetal refab.
~Jim
V
V Offline
Thanks very much for all the great info and Ideas. I will try to find another fender. If not I will attempt to carefully fab out several pcs and weld them in little by little. If I can get close enough perhaps I can make a reverse shape from a friend who has the same fender and use it as a gauge to fill in with bondo. I love this hobby it challenges me all the time.
Like Redgreen says :If the women don't find you handsome they should at least find you handy.
