5 members (Otto Skorzeny, rfs56trk, Buckeye998, Chip O, WICruiser), 121 guests, and 0 robots.
Topics128,101
Posts1,056,172
Members48,436
Hello All,
I have a newbie question for you guys. The pumpkin of my truck seems to be stuck in low gear. It has been like this since I bought it. The truck is a '46 Chevy 2-ton but the differential says GMC. I do not see any provisions for a vacuum line or a manual shifter to hook up to it. There is the proper shifter in the cab for the tranny and one for the 2-speed which does not control the transfer case. Please see the photos in my signature and tell me what the heck is going on.
Thanks everyone!
Sincerely,
j
'39 1/2 ton
3B Offline
Hy Crazy j, your shifter on the rear end is being held in place by a metal strap. The shifter arm is sticking up on the top left side of the diff., it has a 90 degree bend in it, the strap is attached to where either the vacuum or manual shifter would attach. You could attach a manual shift rod, or find a vacuum shift unit and all the control stuff, hope that helps
The two speed lever is held into low with a bracket that bolts onto the front of the rear end, you'll need to get the correct linkage and lever for this set up as it is a lever shift 2 speed.
Lookin at it, that looks like a Eaton 2-speed axle, at least it looks very similar to mine and the ones I have in my manual. Odds are the linkage broke and the owner at the time opted to leave it in low and remove the broken parts.
Might find a shift fork & an electric shift motor to bolt on there, or the vac-shifter and all the trimmings.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
Sounds like the complete rear axle, & housing, were changed. It wouldn't have had the GMC axle in it originally.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Thank you guys so much for the help!!!
I think that i will try to see if I can just put it in high and modify the strap to keep it there until I can get all of the parts I need. I do not plan to haul any really heavy loads in the near future anyway.
I sure hope it goes into high gear!
Thanks again, guys.
'39 1/2 ton
It should slip into high, but I'm thinking it could have a nuetral in it also, betwen high and low, and it is a gear shift so you may have to rock the driveline to get it to go into gear.
