| | | Forums66 Topics128,090 Posts1,056,028 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 12 New Guy | | New Guy Joined: Jun 2007 Posts: 12 | Hello All,
I have a newbie question for you guys. The pumpkin of my truck seems to be stuck in low gear. It has been like this since I bought it. The truck is a '46 Chevy 2-ton but the differential says GMC. I do not see any provisions for a vacuum line or a manual shifter to hook up to it. There is the proper shifter in the cab for the tranny and one for the 2-speed which does not control the transfer case. Please see the photos in my signature and tell me what the heck is going on.
Thanks everyone!
Sincerely, j
'39 1/2 ton
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Crazy j, your shifter on the rear end is being held in place by a metal strap. The shifter arm is sticking up on the top left side of the diff., it has a 90 degree bend in it, the strap is attached to where either the vacuum or manual shifter would attach. You could attach a manual shift rod, or find a vacuum shift unit and all the control stuff, hope that helps | | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | The two speed lever is held into low with a bracket that bolts onto the front of the rear end, you'll need to get the correct linkage and lever for this set up as it is a lever shift 2 speed. | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | Lookin at it, that looks like a Eaton 2-speed axle, at least it looks very similar to mine and the ones I have in my manual. Odds are the linkage broke and the owner at the time opted to leave it in low and remove the broken parts. Might find a shift fork & an electric shift motor to bolt on there, or the vac-shifter and all the trimmings. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Sounds like the complete rear axle, & housing, were changed. It wouldn't have had the GMC axle in it originally. | | | | | Joined: Jun 2007 Posts: 12 New Guy | | New Guy Joined: Jun 2007 Posts: 12 | Thank you guys so much for the help!!! I think that i will try to see if I can just put it in high and modify the strap to keep it there until I can get all of the parts I need. I do not plan to haul any really heavy loads in the near future anyway.
I sure hope it goes into high gear!
Thanks again, guys.
'39 1/2 ton
| | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | It should slip into high, but I'm thinking it could have a nuetral in it also, betwen high and low, and it is a gear shift so you may have to rock the driveline to get it to go into gear. | | |
